Remove the black soot from the last pass. Allow interpass temperature to fall below 150 degrees.
By dropping the voltage all you've done is narrowed up your spray arc. Drop the WFS leave the voltage the same within reason.
Less amps maybe 300-320A, but keep voltage around 28V
The two cover passes should be made at a slightly lower amperage but with the same travel speed roughly. Don't reduce the voltage, voltage doesn't affect you amperage, MIG machines are CV. Constant voltage. The wire feed speed controls your overall amperage. I'm struggling to understand how you are developing spatter, that flange looks like 12-15mm thick and the tube looks about 8-10mm you should be firmly in spray not globular.
this.Think the pipe/flange is an example of what he would deem acceptable.
right, it wasnt cleaned after the first run.Third pass full of holes in the top 50%. looks like you're welding into some filthy plate there to be honest and you can see the second pass wasn't cleaned before the third.
12lpm is far too low. You'll most likely suffer from nitrogen embrittlement. Have you tested any of your welds? Dye Penetrant, Macro Etch, destructive Testing?
1lpm per 0.1mm of wire? Who on earth invented that. Gas flow is dependant on the size of your shroud, CTTWD, travel speed, joint configuration.
Any literature from manufacturers recommends 15-18lpm for a small shroud, 18-21lpm for bigger shrouds found on the likes of a binzel 305, 405 etc.
Gas flow is too high. That's classic symptoms off too much gas.i meant above 25lpm, not below. we have very sensitive valves. so what we see above in post #12 and there, these were done with 25+ lpm and around 30V what is the reason of these waves? i want to avoid itView attachment 117558
As I said your gas needs to be 18-21Lpm!!!
You need to get one of these.
Depending on your wirefeed speed and wire diameter your voltage could also be too high.
What brand Welder are you using?
Is that red painted thing actually going to be a product.always tried to run stringer beads but now its easier for me when i slightly weave, i mean start, stop for half of a second push forward and stop. turns out flatter and more spilled than it was before
a12
a14
would be nice to do such things in one run without stopping. its either my wrist or gun cable being stiff or both. hard to keep push angle but ill try it next time
all of this was done at 31V 12m/min 1mm wire 18lpm omix
lincoln/bester magster 501W
I hope not. Why on earth have you multi runned round those gussets
They can’t be any more than about 6-8mm thick and you’ve stacked a 30mm leg on it. Please tell me it’s a mess about. The fact you’ve painted it might suggest it’s not.
