- Birmingham
I've got no spark on the old ride-on mower. Tried holding the HT lead a few mm from the engine while turning it over and no spark, HT coil measures 2.6K ohm. I understand how a points driven system works, but this one has a magnet in the flywheel to induce current in the coil and I can't get my head round how it's wired. One end of the HT coil is connected to the frame with a ring terminal and the frame is bolted to the engine to complete the circuit, the bit I don't understand is a second ring terminal under the same bolt goes to a wire on the ignition switch which grounds it to stop the engine, how does grounding an already grounded wire stop the engine???
I must have my stupid head on today as there can't be a much simpler ignition system
