Depends on joint configuration and thickness of the parent metal. For example with 10/12mm plate, fillet joint you'd want to be around 100 Amps. Straight in to 5 degree push angle. Tight arc. Keep a small tight bead for your first pass. If subsequent passes are to be made, run stringers or in some cases you can weave less that 2.5 rod diameters.What kind of welder are you using? Can be hard to get the exact amps for a buzz box but I'm thinking in and around 90ish
The one joint i can never get the same results on,in other words i'm rubbish![]()
I haven't done any for ages and it's like learning to weld all over again every time.Your Welder probably wouldn't run them unless it's three phase or has a dedicated Cellulose modeI have an inverter welder . The weld pool keeps running down the joint no matter what I do its mostly the joint . Would 6010 be better
No but if your welder runs them it will go v down as an alternative (don't do this with a, 6013).I have an inverter welder . The weld pool keeps running down the joint no matter what I do its mostly the joint . Would 6010 be better
That's because of gravity helping you o. V down but you won't have any real amount of reinforcing generally and hardly any penetration.I can do vertical down ok but not up it driving me mad
Welding tips and tricksCan you recommend any good vids
Would my 160 amp inverter run 7018 I can get orelikon 7018s . In the local welding shop
Up date on my vertical welds I got some 7018 rods and there much easier do vertical welds
