123hotchef
- Kent
sand or a fire blanket
correctBucket of water might be best as the jet from the extinguisher might send some of the burning sawdust flying, but definitely water for wood fire.
was working at a factory and a rather large belt sander set on fire because of a large build up of sawdust set on fire . which extinguisher would u use to put it out and why![]()
Surely the old colored ones had some writing on them too?It was an EU law that changed the colours -a pet hate of mine. Apparently it was because of a small minority who are colour blind. As a concession to Britain they allowed us to keep a small coloured band around each one.
Will it change when we leave? Don't be silly!
I have been in maintenance in the timber industry for 25 years and have seen a few fires. They are ok unless they have a draught, i.e motor fan, pierced airline, etc. Always try to put it out with slow water or removing it as said. The worst ones are the ones in extraction systems (luckily only seen one)
When I was a lot younger, just started at new job, there was a fire in a 40ft high sawdust storage silo, fire brigade turn up and go to open a door in the bottom.
Maintenance guy : DON'T TOUCH THAT DOOR!!
fireman : don't worry it will be all right.
MG : don't touch that door.
F : look, I know what I'm doing.
MG : I'm telling you, do not open that door..
F : I need to get water in.
MG: Put it in the top, there's a small port.
F: nah, this'll do...
BOOM!!!!!
Fireman was thrown across the car park!!!!
We had a lucky escape a few years ago.
Directly next to my warehouse is a pallet repair business. One night someone decided to rip open the cladding on the building and pour in a gallon of petrol. All on cctv but wearing a hood!
Fortunately stacks of pallets and crates of pallet blocks don't burn as well as you would think. What saved him and us though was that the fire burnt through the main alkythene water pipe. The fire burned for 2 hrs before it was finally reported. Right next to a busy road. I know it was 2am but plenty of passing traffic.
He lost a transit van and a stack of pallets. Could have been so much worse - thank God for that waterpipe.
Next time I'm at the yard, I'll take a picture of the aftermath of a sawdust/shaving silo fire. Not sure what caused it, but 4x25hp fans sure did help it along
They banned it to save the ozone layer - I wonder what a burning car does? Halon is still allowed in aircraft and military vehicles because it is still the best. A 1kg Halon is supposed to be as good as 10kg CO2. Having said that for wood fires nothing will beat water.
It was banned for the cancer causing. The Ozone layer was tagged on as it was going favour with the tree huggers.
It is no longer in use and is being phased out. Normally at the end of the units life. 5 years after a DTR.
Water extinguisher's are mainly found in areas of food production. Normally farms.
A 6lt foam has a higher rating than a 9lt water.
As to water being best for a wood fire, sadly not. Foam will beat water on a smouldering wood fires. as it will "seal".
Many systems in machinety spaces, turbine enclosures and such wre replaced with " water mist" which is more an un aspirated afff foam spray system
Bosley Mill is the dust explosion fire of note
I used to work in a small (6x12m) shopfitting w/shop. We'd been using the usual stuff; robital sanders, table saw etc. As always the air was full of fine dust [mainly chipboard and MDF] so retired to a small office for a brew when there was a flash and a rolling woooooooff, followed by the door pinning me to the opposite wall.
The propane heater had ignited the dust, we used to leave the doors open after that.
You are very lucky!!!
Ive had an extensive briefing from the inspector, Investigating Bosley
On another note, I sit next to the lead investigator looking after Didcot, it ain't a pretty storey
