123hotchef
- Kent
Sounds like a his and hers haven
Jetboil is the way to make quick tea and coffee.
Got one in the van , spot on for a pot noodle where ever you are too![]()
I carry a trangia meths stove in the grab bag
so what is the difference between pure sine wave and modified sine wave ? I got to get this right for my needs, no point in buying twice
Seems very inefficient to convert 12vdc > 240vAC > ~20v dc to charge a battery...
Kettle: buy a 12v camping kettle or make a twig-burning rocket stove out of a tin can.
it is dont milwakee and makita do a 12V charger?
Hmmm, so the 30 min rating is lower than continuous... so continuous must be less time than 30 minsread the small print 2000w is bull carp
Continues AC Output Power: 800W
● 30-minute AC Output Power: 700W
● Maximum AC Output Power: 1600W
Indeed, done a couple of 2Kw inverter installs, we use 95mm2 cable to the batteries and keep the lengths as short as possible preferably under 2m to minimise volt drop. When you're pulling nearly 200amp from the batteries (testing to max and overload to ensure it first warns us then shuts down properly) you need a decent battery bank, usually around 1000AhGood morning 123hotchef.
To boil a kettle on a 12v to 240v invertor is a scary proposition. A normal kettle here in Au is between 1600w to 2000w at 240v. So assuming 100% efficiency (just for arguments sake)
P=IV
2000=I*12 so
I (current)=2000/12
1=166.6amps
That means you will require significant welding leeds from the battery to power the invertor plus the 12v battery will need to be 'QUITE' big![]()
