The Z'eer
- Essex
I've tried both heating it & thinning it until it was like water but it still wouldn't spray using the cavity nozzle!
Be careful not too thin the product too much. If you thin gravitex stone chip with any more than 10% thinners it will droop on vertical surfaces & crack when it dries! I just sprayed 7 tins under a car & the inner wheel arches and learned from my mistakes!
Best method I've found is to store it in the hotpress overnight, mix in 10% thinners & spray 2 coats at 70psi allowing each one to dry for at least an hour, overnight is better. Try not to apply it too thickly otherwise you will get sags & drips.
How odd! Why do you think it wouldn't spray using the cavity nozzle? Another nozzle was used instead?
It probably will be Gravitex that I apply, so thanks for the hints and tips! I will practice on a scrap panel before application.
