I'd imagine you will see a lot of it Going on.No need to go to a firework display,go and watch a gouger.![]()
The great think about that is it doesn't need to be metallic or conducive.arc air slice is something i want but dont want, being abel to smash a hole through pins when needs must would be amazing ( not plesant but if needs must ) and probaly a lot easyer than drilling chewing gassing your way through
Yes. In seconds. Bricks, concrete, all metals as deep as your lance will go.i really want one now, so if say there is a concrete shutter wall reinforced with god knows what stopping me drilling it, and everything else has failed to get a hole in it i chould just burn myself a hole through it ?
Sure do Richard.I'd imagine you will see a lot of it Going on.
Thought so mate.Sure do Richard.
Lots of bubbles I should imagineYou should try them underwater, it gets interesting!
I guess underwater you would fire them up with an arc? I've always just used a cutting torch to initially light them up but I've seen some sort of battery pack advertised to get them going
Make sure there's somebody out in the street with a two-way to tell you when the coppers are passing. It will be hellfire hot down in the vault.![]()
