julianf
- devon, uk
Sometimes I see used chassis that have been dipped.
How does this work? I mean, how can the internals be properly cleaned up before dipping?
I kind of expect people to blast the outside, then acid dip, and metal dip, and forget about all the junk that must be sitting inside.
Has anyone here confidently done one, and what method did you use? And did you look at the job with an endoscope afterward?
Rust cant continue without air and moisture, the temperature involved in this process is huge and any moisture is driven out of every nook and cranny. Galvanising will then coat/seal in all the multilayers of steel inside/outside of the chassis sections ( of which there are many) even if its pitted or there are flaky bits of steel in there, the whole lot gets covered. There is no other process that can achieve this with the same long lasting results. Do all your repairs,clean it, stick it on a trailer, take a cordless drill, go down to your nearest galv company, get the foreman out, explain to him you don't want it coming back like a banana , ask him where he would like the drilling's, explain there will be no extras.Job done and you will enjoy a rust free chassis for many years to come
