Aye, I could get near enough 100 ltrs into the tank, which helps the range a bit.....http://go.jeep-xj.info/HowtoFuelTank.htmpart of the issue with the XJs here was they weren't sold as long as they were in the states so the part supply was much less, plus they cost about 3 to 6 times more here new
hard on fuel if going round the doors but not overly terrible if your crusing I filled the one I was driving in Canada, went to Toronto and back (return journey at warp speed...someone else driving) (2-3 hours drive each way) and ran to town and back a few times before the red light came on
Why does land rover do different from the others to have the 3.5ton capacity?
By making the driving position (unless your a midget) as uncomfortable as designably possible .
Malc
6'3 here. Land rovers are rubbish as stated earlierBy making the driving position (unless your a midget) as uncomfortable as designably possible .
Malc
and I am only 6'3 and fit fine in a Defender. Though I learned to drive in a real mini and used to run a Morris 8 then a Minor, so compared to them it is greatBy making the driving position (unless your a midget) as uncomfortable as designably possible .
Malc
I'm 6ftIm only 5'8 so i find it ok![]()
and I am only 6'3 and fit fine in a Defender. Though I learned to drive in a real mini and used to run a Morris 8 then a Minor, so compared to them it is great![]()
Mine has no bulkhead behind the drivers seat, it has a tubular bar which means you can get a bit more legroom.How can I ask
The only position (only ever driven a works defender ) I get semi comfy in is legs akimbo either side of the wheel vitrually where I hold it ... And the drivers window down no matter what the weathers like rain hail or snow as it's the only place for my right elbow to go .
But that said I've come to the conclusion while there may be a sweet spot in welding ... For me and land rovers there isn't ... Aside from me watching ppl weld them ... If we were all the same the world world be a starange place
Malc
