hope this makes sense...this is supposed to be a top down view (assuming frame is lying flat) of a frame
40*40*3 box with 60*40 in the middle
a fillet corner? weld for each of the numbers
I've read you should alternate sides to help with shrinkage/distortion but not sure if you should be aiming to get as far away from the last weld as possible...like 1 then 16, or side to side 1 then 8 etc
also would it be better to do each side of one join (2+3) then 14+15
or maybe 2 then 11 then 7 then 14
cheers
cheers
