What is this or rather...
  1. Hood
    Hood Forum Supporter
    4,401
    Carnoustie, Scotland
    What is this or rather what/how is it used.
    It is obvious a dial indicator and says it is a Torque Tester.
    I have a feeling it may have come from the Edzell air base many moons ago.
    Size wise it is approx 95mm diameter.
  2. pdg
    pdg Member
    10,496
    Wiltshire
    I reckon it's very incomplete, being a part of a torque wrench testing unit (or similar).
  3. Ian James Forum Supporter
    219
    South west scotland
    It could possibly be a gauge for torque plus degree's as I see it goes to 180
  4. Hood
    4,401
    It has a lug on the back like other dial gauges, see pic. So kind of looks like it would be used in a similar manner to a DTI.
    That is a possibility.
    Ian James likes this.
  5. pdg
    pdg Member
    10,496
    Wiltshire
    Move a lever against a known resistance, measure the deflection...
    Hood likes this.
  6. Hood
    4,401
    Looks like it may be something like that right enough.
  7. jordan1 Member
    1,467
    Yorkshire England
    Could it be used in some way for calibration?.
  8. Hood
    4,401
    I would assume that the image @pdg posted is for that, so looks likely that is what it may be for.
  9. Maker
    Maker Krombopulos Michael
    5,436
    Earth dimension C-137
    What are the units on it? I bet a big, easily read dial would be good for our resident YouTuber.:D
    doubleboost likes this.
  10. Hood
    4,401
    Just numbers, nothing else to state what they are.
  11. doubleboost
    doubleboost Forum Supporter
    1,913
    North Easr England
    Looks like a DTI that has been modified for a specific job
  12. Hood
    4,401
    It is like a DTI but there is no return on the plunger, it stays where it is pushed.
    Doesn't look like it has been messed with at all even the anvil is still in the bag.
  13. pdg
    pdg Member
    10,496
    Wiltshire
    Staying where it's pushed makes even more sense for a calibration rig.
    Some have a secondary telltale type needle/pointer, that one you turn the wrench until it clicks (or read the wrench dial) and then you can release the tension and comfortably read the rig display.
    Hood likes this.
  14. scottmk1 Member
    459
    Scotland
    It's a 0-200 scale not 0-180 so still looks like it's measuring thousands of an inch
  15. Hood
    4,401
    Yes, noticed that after I looked again, seems weird there are no units on it. Will have to measure today and see if the movement corresponds.
  16. scottmk1 Member
    459
    Scotland
    Yeh. The red numbers are also a mystery
  17. Hood
    4,401
    Yes, certainly not mm if the black ones are inch.
    Clearer pic of the dial below.
  18. Hood
    4,401
    Just measured, the 200 is equal to 40 thou, so not in inches.
  19. bigegg
    bigegg I drink and I know things. Its what I do.
    3,061
    Leeds, uk
    There's almost 8 in lbs to nm?
    So *could be dual units with red being nm, black in lb f ?
    <Edit>
    No.
    120nm is only 13.56 in lbs f
    The dial shows it as 15...
  20. Hood
    4,401
    40 and 5, 80 and 10, 160 and 20 etc are all showing the same lines on the gauge so it seems exactly 8x the red value for the black. So far I have not found torque values that equate to that, then again haven't tried too hard :D
Advertisements
