Casting Phosphor Bronze
  1. Anyone cast with Phosphor Bronze?
    I need a 25mm long piece of 50mm diameter bronze bar to machine a gear for the cold saw I have.
    I can buy a billet of the right size for £20 but I happen to have a length of hollow core PB sat in my junk pile that I could melt and cast into a disc of the correct size.
    I have some crucibles but my forge is out of action so the plan is to dig a hole in the garden, fill it with charcoal, add an air supply and melt the PB.
    For a mould I was just going to use a piece of steel pipe with the end blanked off, PB melts at 930°C so the pipe should get hot but not melt - will the bronze fuse to the mould?
  2. pondy
    pondy Member
    1,163
    chedburgh, suffolk. uk
  3. outofthefire
    outofthefire Member
    1,764
    Leeds
    Personally for £20 i'd buy the stuff if its for a gear.
    Wendelspanswick and brightspark like this.
  4. outofthefire
    outofthefire Member
    1,764
    Leeds
    Bare in mind i'm a yorkshireman with short arms and deep pockets and i'd buy rather than recycle in this instance :laughing:
  5. doubleboost
    doubleboost Forum Supporter
    2,021
    North Easr England
    I usually cast aluminium bronze as it is very clean & stable
    It would be possible to melt the hollow bar and re cast it
    But as has been said i would just buy a bit
  6. brightspark
    brightspark Member
    22,471
    yarm
    not worth messing about for 20 quid
  7. gordon stephenson
    gordon stephenson Forum Supporter
    5,718
    Skelton in Cleveland U.K.
    Is not the hollow bar of sufficient size to shrink a centre into it and cut the gear on the O/D.
  8. No, unfortunately what I have is 500mm of 1" OD with a 5/8" ID, it's been sat on the shelf for about 25 years!
  9. the snooper
    the snooper getting older by the day
    19,820
    Hull UK
    pffft call yourself a yorkshireman, part timer :laughing:
    Shox Dr, Parm and brightspark like this.
  10. pdg
    pdg Member
    10,697
    Wiltshire
    I'm a southerner and I'd have a shot at casting it ;)
    If it doesn't go to plan, you've lost a bit of time and a piece of stock that's been taking up space for a quarter of a century.
    If it works, that's £20 you can fritter away on fast women, cheap cars and loose booze :laughing:
  11. brightspark
    brightspark Member
    22,471
    yarm
    and where abouts is that . sounds like heaven . I want some of that :laughing:
    julianthegypsy likes this.
  12. awemawson Member
    Tell you what - I'll give you £20 for your cored bar and you'll be good to go and get your blank :clapping:
    :sheep::sheep::sheep:
  13. Ton-up
    Ton-up Member
    966
    Essex, England.
    Wouldn't it be a hell of a lot weaker than bar material? May be alright for a bush or bearing, but not gear teeth.
  14. brightspark
    brightspark Member
    22,471
    yarm
    only if the grade of bronze used wasn't suitable
Advertisements
