W.olly
- Radcliffe, Manchester
So got myself a cheap, yes that says it, Berlingo.
First time i have been ripped off when buying a car. It was meant to have a replacement rear axle, but it hasnt and that is on its way out as well as the front brakes need discs and pads and a front spring is snapped.
First problem that i need to sort out though is the front either wishbone or hub.
I have done a fair few rebuilds on front ends inc the wishbones but not yet found this. Now there is play in the ball joint when all fitted together with wheel rocking when jacked up. but now i have removed the hub from the wishbone the ball joint is tight.
What are the chances of the hub being knackered ?
I will be removing it tomorrow if i get chance a si need to so i can fit the new springs when they arrive.
Thanks
Wayne
Thanks
Wayne
