- UK
Can someone recommend a decent pro/trade make?
Fed up on these cheapy junk soft alloy ones that fall to bits.
Thanks!
Thanks!
Do you need something to comply with hse 2 bar (30 psi) limit?
EDIT> as far as i am aware there is no legal requirement to reduce pressure just a recommendation.
I remember being told about that at college in the 80's and I've yet to see one in use
We have them ware I work, stupid things, I can generate more pressure in a good fart.
There is no legal requirement, we suggest you use a low pressure or silenced gun to cut down on the potential for exposure to noise. Some realy good options out there but quite spendy
Get these, must have had mine three years. Cheap anyway just but a box of them if your guys keep busting themThis is mine;
It's got brass internals and tip and a Delrin body, I drop it all the time and it's never missed a beat. It's a Cejn 205, it seems they're still in business and make a few very fancy looking ones with all sorts of clever tip attachments.
Fairy snuff, but 30 psi is not a lot of use when you need a blow gun to actually do anything useful. Mine is connected to the compressor's full output.
This is also true, it will most probably also inject oil and metallic particlesThought all the HSE stuff was about if you direct the nozzle at your skin it can cause an embolism,
