Shox Dr
Chief Engineer to Carlos Fandango
- East Yorkshire
Just found this stuff called Zilt Sticks. Thought I would post up as Zinc and Galv repair etc has been discussed a lot of late.
http://www.zilt.co.uk/
quote
We are currently producing an alloy in stick form for the repair of galvanized items. These are similar to Zilt sticks
Alloy of Tin, Lead and Zinc produced in stick form.
Length Approx 250mm
Weight Approx 100g
Thickness Approx 9mm
We sell this product by the kilo, there are approx Ten sticks to the kilo
Methods of use
If the item to be repaired has just come out of the galvanising bath and hence is still hot, the stick can simply be rubbed over the area required.
If the item is cold The method for there use is as follows:
Heat up the area of galvanising to be repaired ( take care not to exceed 200oC as this will damage the galvanised surface).
Heat up the end of the stick with blow torch or similar until the stick starts to melt.
Rub the end of the stick onto the area.
Re heat the stick and surface as required
quote
Length Approx 250mm
Weight Approx 100g
Methods of use
