Hello all,
As the title suggests, no penetration. I know this has been covered a lot but after reading through all the posts Im still at a loss.
I'm using a Clarke 150te with Argoshield light. I've tested flow rates between 8-15 lpm.
I'm trying to weld 2mm plate, I was using .6mm wire and even going up to the settings for 3mm it would not penetrate. The sheet metal was spotless, and I went over the whole thing with a grinder beforehand (it was new anyway - just wanted something to practice on) I thought the earth may have been a bit dodgy, so cut off the old knackered clamp and just clamped the wires to the sheet, but this didn't make any difference. I then changed to .8mm wire and it did penetrate slightly, but the settings were high and this seemed a bit brutal for what I need it for. I've checked the tensioner and everything is fine..
The actual welds look ok, no splatter, right colour, everything look ok... I could see some of the welds glowing red hot, but as soon as I checked the underside of the plate... nothing... still glowing but no penetration
The last thing that I,m thinking is that its plugged into a normal 13a socket, but even this should be ok for 2mm plate?
So if anyone has any more suggestions Id be really grateful. Its driving me mad!
