Roberto Abdala
New Member
- México
Hello, I have a Yanmar L100 marine engine and I can not turn it on, my logical conclusion is that I do not have compression because I already repaired everything else, gear, valves, gaskets ... Then all I have left (according to the manual) is The compression, I have to check the piston rings but for that I have to remove the generator and with no extractor I have been able, I do not know if I have a pin or something that is not seeing or that the shaft is rusted with the crankshaft ... Then I need help to remove the generator and check the cylinder rings. Thank you.
