I already have a barn-workshop with a 32A MCB protected spur (6 mm. T & E) from the consumer unit in the house feeding 'several' 13 & 16 Amp. wall-outlets wired-together as a workshop 'ring'.
Running off that; there`s a large fridge/freezer, drill press, compressor, arc-welder, flourescent-lighting, grinder/cut-off saw and many 'portable' wood/metal working power-tools.
I understand the 'diversity' aspects of electrical power use.....but if I get a large MIG (as I hope-to in the next week or two) should I consider a (new) single 'dedicated spur' serving an isolator/contactor with a 16 and a 32 Amp. socket, just to run the 2 welders.
The house` consumer unit isn`t too far`as a cable run from the barn/workshop and I have to-hand a spare consumer-unit bay, a 32 Amp. MCB and a drum of 10mm. T & E ('old colours'; but who`s to know out-here in the 'styx').....so, aside from having to drill a hole through a 3 ft. thick loose-stone wall; the job would be easy and cheap to do.
A good idea perhaps?......What do you all think?
Kind regards,
Debs.
Kind regards,
Debs.
