Hi,
I've read some two year old post on this mig welder but it's 50/50, so i'm just going to ask myself. What do people think of this welder as I don't have a big budget. So what we thinking?
Introducing the new Wolf Combination Gas/No Gas MIG Welder
With many new attributes, this welder offers both gas and no gas MIG welding.
To get you going a FREE starter kit is also included.
The welding current range can be set from 30 amps-135 amps.
Fully adjustable wire speed
A smooth DC output current provides you with extra
strong, clean welds.
Turbo fan cooled for extended duty cycles
Non-live torch
Large carrying handle with extended arm to easily caryy the welder or move the welder along on its wheels.
The comprehensive accessory kit includes:-
1 x 0.45Kg spool of flux cored MIG wire
1 x 0.45Kg spool of 0.6mm mild steel copper coated MIG wire
2 x 0.6mm tips
2 x 0.8mm tips
1 x spare 0.9mm MIG tip
1 x spare shroud
1 x 0.6mm / 0.8mm wire drive roller
1 x Gas cylinder of CO2 gas
1 x mini gas regulator
1 x combination chipping hammer/wire brush
1 x face shield with CE DIN 11 lens
Technical Specifications:-
Turbo fan cooled for extended duty cycles - 25 amps-135 amps
6 selectable power settings
Smooth DC output current
Non live torch
Fully portable
Operates from a 230V single phase supply
Weight 29kg
Non-live torch
2 x 0.6mm tips
2 x 0.8mm tips
1 x spare shroud
Non live torch
Fully portable
Weight 29kg
