Question is this:-
The local group of Witches are wanting a portable couldren. They want to use it to smelt aluminium or make alcohol or soup, perfume not sure WITCH.
In short like the image, couldren and burner is 800 MM from top to bottom.
Estimate weight to be 100 KGS, at 660 deg C when loaded and on full chat.
Intend on supporting from top only, using two A frames. Then pour the contents out.
Is 25MM X 25MM X 2MM thickness ok to use???
Thanks.
