Nah, that's wrong you'd be putting both speakers on the left channel, @500e has got it correct.As for the speaker leads, one speaker's leads should go to block II, pins 5 and 6, and the other to pins 7 and 8.
I've seen work that was done by someone with a degree in electronics and I'd say wiring a car stereo would have been beyond his abilities, I'm not sure he could finish wiring a mains plug with 2 wires already doneOnce upon a time you didn't need a degree in electronics to wire in a car radio.
To you and me it may be all there in print but sometimes people need a bit of help when presented with lots of information they are not familiar with.You have it all in print on the label![]()
"Wire both up, both lefts together and both rights together.
That way will give you most power and will still be split."
Hmmm - not sure about this - the front amp would then be firing up the fundament of the rear amp (and vice versa) - If your lucky one amp would blow up. If not they both would.
Thats what I think anyway - but what do I know???
