pedrobedro
Man at Matalan
- CX near Chesterfield
I have bought a cheap pedal with two plugs, a two pin and a 3 pin. I need to swap these for a single 5 pin. I know the pinout for the socket on my welder has two for on and off and the other three holes are max, centre and min according to the diagram. The two pin plug for on off is self explanatory but the three pin I am not sure of. It is a 10k potentiometer and when I put the tester probes in two of the holes I get a reading of 9.78, near enough 10 and if I press the pedal nothing happens. With the probe in a different hole I get 9.78 and when I press the pedal it drops to 0 and if I swap it into the other it goes from 0 to 9.78 so I assume the common pin is the one I didn't move and the other two are min and max but which is which? I'm sure if I get them wrong the pedal will just work backwards but any ideas or has anyone already done a similar swap.
