- UK
I need to build up some surfaces on a worn 15mm plate. It forms part of a machine that has been worn out through high tensile steel being repeatedly pulled over its surface in a few areas.
A few problems; i don't want the plate to pull upwards as its welded, and i need to be able to blanchard grind it flat afterwards so need a wire that is not too tough. I need awire that doesnt cause a boat load of feed problems.
We won't be giving it as much stick as it has previously had so i'm wondering whether to just build it up with normal MS wire.
Any thoughts?
Any thoughts?
