May have to get a little puller on it tomorrowMaybe the grub screw has caused a burr, on the shaft that could be protruding into the rollers threaded hole or just a little rust
Give it a decent pull,
I've tried to remove it today my puller won't go under the wheel^^Would not do that ^^ You are likely to strip the gear teeth on the gear box (think you will find some are nylon)
Go easy with a puller as you don't want to bend the shaft.
Thanks for the offer mate it's fine now but@Shoggi How much clearance do you have? See post #4 http://www.mig-welding.co.uk/forum/threads/sykes-and-picavant-bearing-puller.72072/#post-978087 - you're welcome to borrow it if you cover p&p +insce both ways?
Wouldn't be until mid next week though.
