H helpweld New Member Messages 1 Feb 20, 2012 #1 i have a ,clark 180 wirefeed, and for some reason when im welding it tends to spit and sputter so i can never get a clean weld. does anyone know the problem? Last edited by a moderator: Feb 20, 2012
the snooper getting older by the day Messages 21,063 Location Hull UK Feb 20, 2012 #2 what gas are you using ? pure co2 causes more spatter then a mix if its gasless they do tend to spatter more
shenion Tool Pack Rat Messages 7,582 Location Stone Mountain, GA USA Feb 21, 2012 #3 Usually an uneven wire feed. Could be liner is plugged, bad tip, bad neck liner or reel to tight. What wire are you using?
