Hi guys, my first post... and for a change i thought i'd ask you all a question
I've used an Arc welder in my distant past and was ok'ish on 2-4 mm stuff.... more recently i've used a Mig, though i should add i mostly did basic tacking with it (rebar re-enforcing ) and only occaisionally did anything like proper welding..... but that was some years ago.
Anyhow, i will be in need of starting again so i can weld the sills and boot of my Disco.
Lots of good advice on here about what budget welder to get, but my question is even more basic than the norm.
I realise Arc is hard to do on thin steel, and Mig is the norm, mainly it seems because you can get the amps down low... if that is the reason , why can't an Inverter DC Arc welder do as good a job as a Mig? It would seem to my mind that as the amps can get so low , and as it's Dc it should surely do the same job.
Obviously an Inverter is cheaper to start with and requires no gas so running it would be cheaper...... I expect there is some very obvious reason why it's not done.... so please oh knowledgeable ones what is the reason?
Dave
Dave
