Can't you use a foam attachment on a power washer ?
One tool, two uses.
That's actually not that helpful, because most of the product then never touches the surface, you actually do want a foam with enough water in it to break the surface tension and work it's way down the paintwork and dirt, it's supposed to just slow down the product to let it work longer not actually just sit on the paint as a foam.
BH did a big writeup on that years ago on DW with some experiments too, it's why their autofoam isn't designed to foam up loads, just enough to thicken it.
You didn’t need 11x cars but you managed to justify that, so go get one
The video sounds was horrible, I'm betting it's nothing but the $30 one with a cheap motor on it.To date I use sub £30 manual pump sprayers for these detergents. But they do only last a year or two then leak or the pump handle breaks. I guess if this pump is high quality and has spares available it might last for 5-10 years.
stick with the cheap ones, they'll work out cheaper in the long runTo date I use sub £30 manual pump sprayers for these detergents. But they do only last a year or two then leak or the pump handle breaks. I guess if this pump is high quality and has spares available it might last for 5-10 years.
I have 11x cars DIY use only. But man this thing looks good.![]()
You are all talking me out of it so far![]()
What type of sprayer?
Shouldn’t you be considering employing your own valet?I have 11x cars
20L or similar garden sprayers. They don't foam up. But they do spray on the diluted TFR with some suds. I use that as a pre wash for heavily soiled cars. Then rinse the whole car, foam Cannon bilt hamber on, rinse and contact wash.
