MoreWellie
- Bedfordshire, UK
has anyone tried to repair a cheap multi tool? I was shown the internals of a cheap multi tool that a friend has where an arm that is a press fit on a shaft has started moving which makes the tool useless.
Easy enough I said drill a small hole through the lot and put a pin in it
After an hour of drilling and trying different drills I have managed to get the centre of the hole just over a mm deep
I suspect the answer is going to be carp drills but I have used 4 different 1.5mm drills and one I tested on a bit of mild steel and it drilled through without any problem
They were unused as 1.5mm isn't a common size on the things I normally do but they were 2 from a screwfix tin set, a normal hss axminster set and the final one from a presto hss set
any suggestions for a different way of sorting the problem
you can see the little dimple (scratch) I managed to make on top of the collar
