Which stainless rod should I use for an unknown grade of stainless I have to weld ?
First test: Is it magnetic or non-magnetic?
That will divide the unknowns by about 2!
2nd Question: Is it sheet/bar stock/structural section ?
OK, Now I'm struggling to narrow down the alloy
Hi, not magnetic, and it's a pair of stainless hubcaps, stamped sheet.
Be very careful I tried to weld some Ford hub caps from I guess the early 20s. You couldn't tell but the Stainless was paper thin, formed over a centre cap. So you will need far far less Ampage than you think![]()
. Also not all Ford caps are pure stainless, The stuff some are made of escapes me at the moment.Yep they are extremely thin, think fag paper. Also not all Ford caps are pure stainless, The stuff some are made of escapes me at the moment.
it damn well escaped me as well in a puff of smoke
. Luckily he wanted the logos filling in, to put on another build, so I managed to do the job, wasn't easy I can tell you
