robdxr2 Member Messages 145 Sep 5, 2013 #1 Hi im trying to find some 1.7mm mild steel sheet but I can only find 1.5 and then 2.0mm? is it an odd size and will that make it expensive
Wendelspanswick Member Messages 6,471 Sep 5, 2013 #2 1.6mm is a standard size, what's 0.1mm between friends?
pedrobedro Man at Matalan Messages 13,078 Location CX near Chesterfield Sep 5, 2013 #3 16 gauge imperial is 1.6 nominal thickness or 1/16"
M MCKDAVID Member Messages 2,785 Location South West France Sep 5, 2013 #4 depends on how much you need if it's in short / small sections then get shim steel, any thickness you like, the problems is if you're looking for a large surface area then no good..
gordon stephenson Member Messages 7,430 Location Skelton in Cleveland U.K. Sep 5, 2013 #5 The difference between 1.7mm and 1.6mm is only 4 Thou, (0.004")
Pete. Member Messages 14,937 Location Kent, UK Sep 6, 2013 #7 Buy a sheet of 1.6 then build it up with 0.1mm of weld
Shox Dr Chief Engineer to Carlos Fandango Messages 17,866 Location East Yorkshire Sep 6, 2013 #8 Pete. said: Buy a sheet of 1.6 then build it up with 0.1mm of weld Click to expand... Don't be stupid, you never be able to do that. Build it up thicker, and then grind it back
