Sean,
Assuming your left and right are looking at the wiring connection side of the plug then yes but look here too.
Note: I'm NOT a sparky!
The 'normal extension lead' bit is bothering me a bit. I'm not familiar with your welder but the usual deal with a 200A inverter or similar is for it to be fused with a 'slow 16A' breaker- they can draw quite a bit of juice for very short periods of time. Taking my Lincoln as an example, machine has a input rating of 6600W (around 28A max draw on 230V) but a 16A slow fuse is specified along with 2.5mm2 flex (same size wiring as a normal ringmain). As long as 2.5mm wiring is used mine will happily run flat out from 13A plug without blowing fuses/tripping breakers. Try and use a 1.5mm extension lead and it'll pop fuses constantly (found that out on a mobile job when my requests were ignored and the sparky ignored/forgot about the max length of lead i had available)
Wiring... 1.5mm 3 core flex is 15A (most regular 13A extension leads). 2.5mm flex is 20A.
Using a 1.5mm/15A extension lead may well result in constantly blown fuses (at best)
