JonnyAlpha
Hi;
Been away for a long while and need to change the welding wire on my Clarke 160EN as its looking patchy.
I am not home yet and would like to order the consumables ASAP, before I order can someone help. I have been trying to remember / find out what size (diameter) the spool is that the wire reel sits on? And what wire this machine uses?
Can I use 0.7Kg and 5Kg 0.6mm Mild Steel Copper Coated wire in this machine?
Does it matter what brand of wire?
Will this do: http://www.wellyweld.com/products/migwire-a18-0.6mm-0.7kg-45880.aspx
If it helps Ill be welding Mini Body Panels on an old Austin Mini 'Y' Reg.
Thanks
Thanks
