Hi All,
Never welded before, looking to start so i dont have to order as much in for my projects.
The first project i would like to do will be in june, it will require butt (or mitre if i want to be fancy) joint welding 5mm mild steel box section (100 x 50mm).
Other than 3-5mm mild steel stuff, i would also look to try my hand at 2-3mm stainless steel at a later date. As well as come aluminium work (3mm).
I've been looking at some cheap options like the Draper 200A MIG inverter 230V from ToolStation.
Should i be looking at MIG for the range of projects i have in mind? would this machine be good enough to weld 5mm mild?
Also a question about power supply, the one mentioned requires 32A supply, what is the process of getting 32A socket in the garage?
Thank you
Thank you
