Chippie
- Newcastle upon Tyne, UK
I need to weld a piece of 20mm tube (wall thickness 1.5mm) to a metal disc that is around 0.8mm thick….The tube passes thru the disc which has a hole to accept the tube…so the fillet is around the tube/disc junction….
The other end of the tube has a flange plate that needs welding to it, the plate is 5mm thick, with the tube passing thru a hole in the flange…..
If that all makes sense…?
What weld fillet would be best? Tig/Mig/mma?
I‘ll try and get a picture later….
