rizzlablue
Hi i have just recently bought a classic mini and as per usual it has lots of rust. So i am a complete novice i have only read lots of theory never used a welder so any advise would be great. I guess i will be welding between
1mm-4mm mild steel what im after is spending £200 or less on a gas/gasless mig that will welder the thickness im after with as much easy as possible. Were will i be able to find some metal to practice with im in kent UK.
Thanks
Thanks
Is the 151te really the only welder worth mentioning what is the 151en like is there a big differance? I no there are meant to be a few cheap welders that will go down to 20amp which would be a bonus on body work. will they not have a high enough top end to weld the structual side of things. If no one has any other suggestions were can i pick up a 151te cheap is machine mart the best place.
