hi all
I need to get a TIG for occasional use for welding cast alumunium and intercooler pipes I have not used one for about 30 years .
I don't want a top of the range or a hobby one can anyone give any suggestions?
Thanks in advance Dell
Hi GreasedUpDeaf Guy
Thanks for the quick reply £1000 ish 13 amp or three phase although I don't think I need three phase as for thickness intercooler pipes are 2/3mm and I weld them with gas at the moment so I don't need to use it for them but I am having trouble getting cast sumps hot enough with gas to weld that is the main reason I am looking at TIG the sumps are 8mm at flange down to 2mm in centre but I would rather have one a bit bigger than needed.
Dell
You'll be fine with a 200 as sump castings although thick are usually vee'd out both sides and welded slowly to allow the oil and contaminants to be leeched out by the welding process. Also they tend to not be that big and will heat up overall fairly quickly once you get going and you'll find yourself not needing full power to maintain a puddle.
Brad is right, 300 amps will let you light up and weld instantly BUT you'll normally find the contaminated metal won't allow you to go rock n roll on it right away until you have got a few "cleaning" passes on it anyway, by which time the part is usually warm enough to do without all that power.
Not trying to be contradictory but I've done a lot of casting repairs and I've mainly done it with whichever 230v tig was easiest to carry to the bench. I also have a big oven which is a real godsend for getting oil out of a casting as it goes super runny and just bleeds out of the pores in the metal. It goes in clean from the vapour blasting and comes out brown after an hour at 300 degrees, wipe it down, rinse and repeat.
I don't do this all the time by the way, only on stuff I think will really have soaked up some oil (like a sump or motorcycle engine casing etc)
If you want to do castings though you'll appreciate something with a duty cycle that keeps up with you as there is nothing more annoying than getting the heat into something and motoring along nicely, only for the thermal LED of doom to light up and announce the fun is over, when all you want to do is wrap up the job and get home.
You might want to think about water cooling too as high amps and long weld times mean melted torches and burned hands if you don't get it right, and a WP26 (big air cooled torch normally supplied as standard with any 200 amp AC/DC set) can be a right pain if you have to hang onto it for a long time.
Lots of choices and it's never been a better time to be in this market so best of luck in your search.
It's a big old Hailey rod oven with the shelves removed, its big enough to get a v8 engine block into or a mer cruiser stern drive leg etc.
It goes up to 350 so plenty good enough for heating up hubs prior to dropping in bearings etc.
Never gets used for rods anymore, who does that? Lol
