BrokenBiker
- Newport, South Wales
This is why I love this forum, so much knowledge
Id suggest Loctite 571 and taper to taper fittings. Its only low pressure, the OP planning on using. If it were high pressure I go 10k fittings in Stainless, NPT or BSPT. If you want high pressure reusable fittings look at JiC.Taper to taper joints should in theory self seal, the ptfe tape is to let the threads slide past each other until it is tight enough to seal.
Problem is that the threads and tapers on mass produced fittings are less than perfect so you will never get them tight enough to self seal.
Stainless fittings will gall long before they are tight if you don't use a liquid sealant.
If you want to get an elbow or tee to point a certain direction once assembled that might not be the same position where the joint is tight. That's where a solid setting liquid sealant is essential to hold the joint in the right position.
