Smallfry
HE's Spartacus.
- Kent UK
I need to mark the centres of some locating pins on an engine adaptor plate I am making.
I have metric and imperial transfer punches, but the master has blind holes. So I put a couple of old locating dowels in the lathe and turned them down so the ends looked like the ends of the transfer punches. The steel seemed quite soft, so I thought I would harden them by heating to bright red hot, then quenching, which is the method, as I understand. Didn't bother with tempering, as it was one use only.
Put the modified dowels in the casting, and turned it over onto the steel plate, the gave the casting a whack, to mark the centres on the plate. Unfortunately didn't work, as it just flattened the points on the dowels.
Can I use a different grade of steel, silver steel perhaps, to repeat this process more successfully ? Will I still be able to turn some points on it with the lathe, and will I need to harden it afterwards ?
Any suggestions ?
Any suggestions ?
