you need a bit of clearance 8 mm should be goodI'm fitting some new valves in a xflow head and the valve stem is measuring a diameter of 0.314" or 7.976mm in new money.
What diameter reamer will I need to source for this? Will 8mm be too big a hole?
Thanks
Darren
that is way less than a fannys hair clearance
Thanks
Darren
No not yet, the new valves don't fit the current holes which are 5/16" , the valves should be 7.88mm or 5/16 but they are slightly thicker stemmed.
