Isn’t Plusgas available in squirty cans anymore? Only aerosols? I haven’t bought any for yonks, but the last I got was in a can like 3in1 oil.Plus gas is great, I've had a couple where the gas has run out before the liquid so I just cut them open and apply with a brush
GT85 is quite good.
I bought half a dozen cans of plusgas a while back, (probably a year)... when I went to use one there was no gas left in it... 2 more cans were the same
proper branded stuff not cheap copy, maybe it was just a bad batch but it was enough to put me off
Diesel always works for me, especially if you can put plenty on - dhich is much easier with diesel than a spray can
Rye Oils easing oil is good gear, 25ltrs of this is less than the cost of two 5ltrs cans of wd40.
Grand if you have space for the big drum.![]()
Did I read here that an acetone + ATF mix makes a good [the best?] releasing fluid?![]()
I don't use oxy acetylene much nowdays but its a must on some jobs . couldn't get the nut of steering trackrod end . it kept turningPlus gas
Oxygen plus Propane /Acetyline
thought that was for getting in not outI was going to say KY but maybe I shouldn't![]()
