BoatBuilderDave
- Ireland
So I got a clarke 151TE, and in fine tradition started to build a welding cart for it. I've got a reg & Argon, and I'm using it with gas.
- Brushing past the welder _will_ change the wire speed, cause you will move the knob as you go past. Then it'll take you a while to figure out wtf is going wrong. It does not have to move much.
- You will probably change the contact tip before you realise that you've just altered the settings.
- If you make a rectangle, with a support across the middle, but you weld up the rectangle first, the cross piece which did fit perfectly is now too long. Not by much, but enough to not fit.
- When you get tired, your stick-out distance varies, this does not help. Neither does dipping the tip in the weld, nor letting your torch angle change a lot.
- It's hard to weld when it's getting dark. You'd think it would not matter, but it does. The auto helmet is great, but in poor light, it's still about shade 3 when it's "clear".
- Dipping the shroud in the weld does not help things.
- It's a LOT harder to make something than to just stick test pieces together. The joints are not all at convenient angles, other bits are in the way. Perhaps you should have done that bit before this bit instead.
- Even if some of the joints don't have full penetration, 1" 16 gauge tubing welded on all 4 sides with 6" long 45 degree braces will hold my weight, so it'll hold the welder easy.
- Perhaps you should tack a lot more pieces together rather than welding them completely, apart from anything else, you get to move the cart around less as you can weld several pieces, then flip it over etc.
- The Clarke is perfect for hobby stuff, but it would be nice to have a longer torch (1.5m is short),
- It would certainly be nice to have things like some sort of Hot Start (is there such a thing for MIG? run at 20% hotter for the first 5 seconds, then tail back to normal as the metal heats up). Clearly, if there are such toys, they are way outside the Clarke 151 price point.
- A Mapp torch will burn off the oil coating on 1" 16 gauge box section so that you can mig weld it. It's a lot quicker and quieter than a flap disk on a grinder.
- If it's within throwing distance of a welder, and it's made of metal, it's HOT, use gloves. The piece I picked up was just hot enough to drop, no damage done, but really I should have known better from casting bronze and aluminium.
the bit you missed in the first list is that you have to make something rather than tack bits of scrap together, in order to improve your skills (in fabrication as well as welding).
. Set your welder back on the cart if you can or modify it so that you don't knock the wire speed control, if you rest your gun hand on a clenched fist, you get pretty much the same tip distance each time. You can vary that by resting the fist on edge of yr palm, or turned thru 90° and resting across the knuckles.
