One of the softer flavours that'll crumple a lot more than a 6xxx series without splitting should the worst happen. 3103 is an ideal choice, 1050 nearly as good. The 5xxx series are fairly popular choices for fuel tanks but they work harden relatively quickly which can cause fatigue issues with simple flat sided tanks as fuel sloshing about flexes the skin hence my preference for 1050 or 3103 which is also easier to shape- stiffness through geometry and all that. I weld 'em with 1050 wire except for any machined fittings & vent/filler tubes etc which are typically 6082 and 6063 respectively so welded into the tank with 4043
