If everybody used the simplest possible solution to get by in life we’d still be living in caves.I'm always amazed/amused how such simple issues asked about on here can get such over-complicated, expensive, time consuming and needless solutions offered, despite the easiest answer being given early on![]()
Treadle lathe?If everybody used the simplest possible solution to get by in life we’d still be living in caves.
Mind you, we still might yet….
I'm assuming OP does have a piece of tool steel, yes I've cut holes in ball bearings using a diamond wheel sharpened masonry drill you may be able to do the same to tool steel but to cut a thread give us a break and to buy a carbide stub drill is cheaper than a diamond off hand grinding wheel. Have a local company cut a thread on an EDM is the best solution for tool steel. I've ever used one once and it is possible to build them DIY same as 3D printers and complex or not I believe this site with it's wealth of knowledge can lay open options for OP then he can decide.I'm always amazed/amused how such simple issues asked about on here can get such over-complicated, expensive, time consuming and needless solutions offered, despite the easiest answer being given early on![]()
Yep , I didn't think to say hardening as to me it's a natural sequence before tempering when using something like a red hot cast iron block as the tempering heat source .Doubtful. Annealing is softening, as is tempering. It would need hardening, after annealing, before tempering?
