Or a flow meter ? Gas economisers would be a bit of overkill for a diy welder, they cost quite a lot. A good two stage regulator would be an alternative and stop a bit of waste.
Gas economiser seems to be the right doodad, thanks. You're right, they are a little pricey. I've been doing a lot of thin mig, stop/start lately and the torch has quite a pronounced surge of gas every time I press the trigger, it's been annoying me such is the price of gas. I stole my good reg for the tig so maybe time to invest in a better one for the mig.
I have been using two of these gas savers for a couple of years. One on mig and one on tig.
I'm not too sure on how much it saves, if any, but thought i'd give it a go.
When i touch the trigger on the mig there is just a steady flow and no surge.
A shorter gas line between the reg and solenoid will help/reduce the volume but won't do much for the inital surge itself? They're only expensive* if you go for a posh all in one jobby like the Elga optimator which are a multi stage reg + surge thingy and flow meter... http://www.gasiq.se/econtent/244/more_info_optimator.html There's a cost estimate calculator on their site which is a bit better than usual 'upto 50% gas savings' as it lets you play with things from a 100% spot/tack welding to 25% tacks/75% longer welds. Unsuprisingly they start with an assumption of spending 1K a year or more on gas
* and even then not spendy compared to a dual stage reg + flowmeter etc
