Damaged
I blame the penguins.
Hi all, wonder if you can help...
When I'm welding something odd seems to happen.
I'm only welding 1" or 2 " box section or angle but now and again the wire seems to burn back and instead of the usual crackle I'm used to the noise stops and I get a process that seems more like gas welding, when this happens the weld looks a bit odd, where I've had the crackling noise the weld has contour lines but when it goes silent the weld is as smooth as a baby's bum...
Can anybody tell me what is going on?
Many thanks, Mick.
Many thanks, Mick.
it was the nut lose on the coil center bolt being tightened as the coil went round put Nylok nut on all ok.
Wire should come stright off coil into wire feed not at an angle. good luck
