BrokenBiker
- Newport, South Wales
Spent from about 10 til now pulling everything out the shed bar the lathe and welding bench in an attempt to declutter (for sale posts to arrive tomorrow) and reorganise so I have a usable space where everything that is regularly used is available when needed...except I also had to incorporate a 10 ton press, bead roller, shrinker stretcher and compressor in there as well and...well, it doesn't fit...
The bandsaw stand is bigger than it needs to be so is preventing the 3d printer fitting where I want it to, but if I make the bandsaw stand smaller I lose the space underneath for the hoover and chop saw...if I put the press along the back wall I can't get the bandsaw out to use it, I have nowhere for the big storage box of filament to go, or the box for scrap plastics...the welding bench is full of tools to sort though, the lathe is full of tools to sort through, the floor is covered in swarf, dust, bits of packaging, polystyrene and spiders...and no matter how I look at it, the compressor won't fit without needing to be moved every time I want to drill a hole or use the wire wheel...
In hindsight the 1500mm wide welding bench wasn't exactly necessary...but if I make that smaller I lose the space for 1 of the tool boxes
Whose idea was it to make a workshop again?
