Hey so attempted my first test on a piece of 4mm mild steel and think I turned the speed down too much and the heat traveled up the wire and to the welding tip and now it's all stuck together. I was able to twist out the tip and remove the wire so I'm wondering can I save the tip or do I need to replace it?
To stop this happening again if anyone can help with settings. I'm using a Sealed Supermig 150
0.8mm wire
Co2/ Argon mix at 8LPM
Power set to Max 2.
What wire speed should I use?
All to weld 4mm mild steel
0.8mm wire
Power set to Max 2.
