These might seem fairly basic question but the only silly question is the one you don't ask....
Anti spatter spray - I assume that this is just sprayed all over the work area to stop splatter sticking. Any particular type I should be looking for and does it need to be cleaned off after work, if so with what?
Primer - the work needs to be clean before welding but I assume weld-thru primer can be sprayed over the cleaned area to stop rust before the weld, any particular type the best for cars and does this affect the future paint job on top?
Once welded what is the best primer to coat the work area while I continue that I can then paint over, bearing in mind I will be spraying the car myself once I work out how to do this........
