terryscott
New Member
Today I plugged my cobel mig tig mma welder in to do a small mig welding job, I was quite far from a power source so I used a long extention that the customer had and it was quite thin, the grinder worked fine but when I went to arc up as soon as the wire touched the steel it made a very small arc, not even enough to make a tack and now when I pull the trigger it just makes a single clicking sound and the wire feed motor does nothing, there is a button inside to feed the wire and this works as it should, I have taken off the gun (euro connector) and shorted out the two pin connections and it clicks the same as the trigger so I know it's not the gun.
What have I done ???
