Ok, I've taken my manifold off my car and all 4 turbo to manifold bolts have snapped flush with the turbo flange.
I have tried welding no less than 10 nuts onto them and every time the weld breaks. It usually seems like it has a good hold at first, but after a couple of turns with the breaker bar the head comes off and the bolt has not moved at all. You can also see after doing the first tack that a lot of carbon is generated ontop of the bolt which surely doesn't help.
After a bit of digging I've come to the conclusion that these are some sort of alloy and not standard steel bolts.
Now I REALLY don't want to sit and drill 4 of these. Have already had the displeasure of doing one and it was a nightmare!!! Took the better part of 4 hours with brand new cobalt drill bits.
Also the 2 at the back have poor access due to being slightly slanted towards the engine. Car is an Evo 5 if that helps anyone, but what I really need to know is what gas and welding wire do I need to make a mild steel nut hold onto these bolts/studs??
I have a Clarke 151TE mig, CO2 gas, Argon/CO2 mix (86/14), mild steel wire (0.6mm) and stainless steel wire (0.8mm) at the moment.
Would the stainless wire and Argon/CO2 mix work? I have not tested it yet. If not can someone please point me in the direction of some proper wire and gas that will get it to hold?
Thanks!
Thanks!
